I recently bought a metzler rear tire, me 880, while on holidays. When I got the tire home it was the wrong load rating so I didn't put it on. A friend suggested I install the tire but put an inner tube in so it would be able to take the weight of the bike better.
Any thoughts on this idea.
I would not, better to exchange the tire you received with the correct load rating.
+1
Your inner tube has no steel or nylon reinforcements, right? It is made of rather thin rubber and installing that inside your wrong-rated tire does not increase the load rating at all. If your tire gives up the tube will not hold it together. It may be that it takes a few seconds longer before the air escapes from the torn tube but I wouldn't feel comfortable relying on that...
Regards
Ditto - get the correct tire. I personally wouldn't gamble on this safety item.
Thanks guys. I thought it was a bad idea. I bought the tire in LA on holidays and live near Toronto so will try to sell it
