1 - 20 of 32 Posts
Of all the things to happen on a holiday weekend....I was riding in the mountains of New Hampshire(Littleton) and stopped at one of the scenic views stops and was putting the LT in the pic when I noticed a bulge in my rear tire. So I basically freak out and baby it back to my hotel. Got out my Anonymous book and looked up dealers...well there ain't any close by.
My options appear to be very limited
call a wrecker and haul it to Merrimack NH(closest dealer 120miles)
baby it to the dealer
would a honda/harley be able to change the tire?
Thanks Guys
Thanks Guys
Limp over to the deep south of Vermont?
I've a set of Metz's you can have for cost and I'll help you mount.
Sending a PM....
Addendum: just realized that MaxBMW NH is closer to you; but the offer still stands.
Thanks Guys
A Honda or Harley dealer might be able to change the tire IF they had one rated for the LT but because of the rear wheel construction, they may not be able to balance it without some type of adapter.
Wheel can be balanced using standard cones on a static balancer.
Robert
Thanks Guys
They should be able to change the tire if they have one in the right size and load rating. I think that there are some Harleys that use the 79V load rating.
Robert
Reactions: tvguy
Robert
I know the front can but why do I read threads about people having to buy or make an adapter for balancing the rear? Beech makes and sells them.
I use the cones on mine with a Harbor Freight balancer. Takes time but works fine.
Robert
Reactions: Flynn
Robert
I have been thinking of getting the HF balancer but had not yet because i don't have " the adapter" I hear people mention. If it needs nothing else, I may just go ahead and get it.
If you buy one please do a write up here. I have heard some folks were not happy with them. It does not have to be wheel/spoke truing accurate to balance a wheel. If you have large enough cones I can see where they would work but I like my five bolt 120mm bolt circle balance adapter. :wink:
Reactions: bmwcoolk1200
Beech, will your adapter handle the three hole R80GS rear also? If so I want one.
Robert
Careful at the Harley dealer. One of the Harley's uses the same size rear tire which they will have in stock. It is not rated for the LT. No matter what they try to convince you of if it fits any Harley, it's not rated for the LT.
Thanks Guys
Call some shops ahead of time and see if they have one (correctly rated). If they can't balance it see if they carry dynabeads or some other internal balancer. While it's not good to ride on it if you take it easy you should be able to get there.
I just went out to the shop and rechecked the rear with the HF cones, fit fine. All they have to do is hold the wheel centered on the shaft, not a big or precise job. I also have a half dozen of other cones of various sizes for my various bikes. Hope this helps.
Robert
Discussion Starter #16
Appreciate all the replies but made it to Max BMW.....already being worked on
Glad you went to max. I have found them much cheaper for tires and most other service than the Other NH dealer.
Rick
Robert
Thanks Robert. I ordered an Ebay spare rear wheel and have a BT-20 in transit so I can get one ready when it is time. I didn't go with the HF balancer but one that had reasonable reviews on Amazon. Hoping it is just a little higher quality than HF but you never can tell by a picture.
https://www.amazon.com/gp/product/B003QT26D6/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
It looked well made with decent reviews and the cones looked like they would fit the rear of the LT without any adapter ( Calibrated eyeball). It rolls very freely, bubble leveler and easily found what would be expected as the heavy spot on the rim.
Sorry Beach, I won't be needing one of your adapters after all. ;)
Only thing it didn't come with was the 3mm Allen to lock the cones. 1 point off for that.
That balance machine looks great, superior to HF by a long shot. I use to make these things but I can't beat the current crop prices. On the photo above the flange is a tiny bit under 50mm. The BMW adapter is a cup that goes over it and has a 15mm hole in it for the cone shaft and to be captured by the cones. If you have a lathe, take a disk of aluminum bore out a 50mm hole about 3/4" deep and then drill a 15mm hole through the whole thing. You now have an adapter.
1 - 20 of 32 Posts
