I ordered new throttle cables from Chicago BMW.I am also going to change the old girls fuel and air filter while I have her skirt off.Anything else I should take a peek at while I'm in there?Any tips or tricks to make it go smoother.I'm not all that familiar with the LT.Only had her apart once to install the Power Commander. Thanks, Jeff
Hi, Jeff -
If you haven't already done it, I'd upgrade to the metal Quick Disconnects (QDs) on the fuel lines after you take the tank off, AND while you have the mirrors off, tether 'em when you put 'em back on.
You're lookin' at a fairly easy job - just take your time. And while you're not concerned about summer heat, just be sure and don't set the fuel tank in too warm a place - gets a leetle outta shape, which makes reinstall an expletive-rich tussle. :eek: Good luck to ya. :bmw:
Thanks Dick.I learned about the mirror tethers the hard way.Also cracked a quick connect last time I had it apart.Guess that's why I need guidance.
2015 K1600GTL Exclusive
Coolant Change
Might as well change the engine coolant while you're at it. Much easier with the fuel tank off. :bmw:
throttle replacement
is really worth it. After I had the new ones on, they didn't seem add much improvement when I tried them, and they seemed to stick and not snap very easy. After everything was togther and I went for a test drive, oh my god, where they easy!
larry
