So these had Threadlocker on them when I removed them, but the service manual does not specify using any.
Is there a group consensuses on this?
There should be no thread locker on those. They are torqued to a high value ( right side and jam nut ). If done properly, they will not come lose.
If you watch jzellers weep hole video, he makes mention of the PO doing a good job not having used any locktite on them.
Excellent. Thank you.
I have seen that video as well as a bunch of the Chris Harris videos, who also doesn't use Threadlocker on these. Just having to melt the threadlocker to get these things off during removal gave me a moment of pause.
My understanding is that BMW used this at the factory and then changed their mind. Neither the BMW RepROM nor Clymer manual specifies thread locker. I used at when I switched to the brass bushings as Tom Cutter sent instructions that specified it to help hold the bushing in place on the pin, if memory serves.
I forgot about those as I still have the needle bearings. If I am remembering correctly, the locker was as you said used on the bushing and the un-threaded part of the pin, not on the threads themselves. Correct me if I am wrong on that Matt. It was a while ago that I looked at those.
That is what I did, but I would have to dig out the instructions to confirm if that is correct.
:grin:
Reactions: bmwcoolk1200
