1 - 20 of 21 Posts
I rode to work Wednesday and back home. Bike ran perfect. Went out yesterday to crank it up and move it and nothing happened. Radio plays, lights come on and just a small click and nothing. Battery has 11.5v. What has happened? I'm really getting pissed off at it. Every other day it's something. About ready to let it go, cheap.
Not much info to go on.
Your battery is low.
ronnieds said:
What has happened?
We don't know what year it is,
how many miles,
how old is the battery, etc, etc.
We understand you're just "venting"
but you haven't told us much!
Still sight unseen, you want it gone?
I'll give you $500 for it!
let the bidding begin!
windshield want hardly move. i charged the battery about 30 minuts and it still will not do anything. i'll try again tomorrow. something different maybe.
Just a thought but you didn't happen to leave the Key turned to P instead of off did you?
Also did you check your trunk light to make sure its not turned on?
Um, battery is STILL dead. :rolleyes:
You need to get well above 12 volts and have it remain there for more than a few minutes to have enough juice to do ANYTHING.
Trickle charge it for 20 hours OFF THE BIKE at 1 amp max and then give it a try. If a lead acid variety make sure the cells are topped off with distilled water to the max fill line prior to charging. Clean the battery posts and connectors with a brass bristle brush before reconnecting, and make sure they are TIGHT.
Then, when it still won't start a week later :rotf:, buy an Odyssey PC680 and a charger designed for an AGM battery. Keep it hooked up ALL THE TIME while parked.
Yeah, it's going to cost about $150, but the The Force will be with you. :D
(then again, you may have damaged the contacts on the starter by trying to start with a low battery issue. Unlikely. That's a 'whole nother ball o' wax, but usually easy to fix)
He's got an Odyssey that's 1 year old. But ya changing a battery for 30 min won't hardly do anything. Give a 2 amp charger 8 hours. Then try it. If your battery won't hold the charge its toast.
Ah, missed that... :eek: The good news is that if the Odyssey is dead it should be covered under their 2 year full warranty. I would take it to a local dealer instead of dealing with shipping.
I had one die prematurely and they covered it, even without the original receipt. Pretty sure there is coding on the case that gives the manufacture date.
I've always been impressed how many times an Odyssey can be brought back to a useful life - when apparently toasted - versus lead acid. I seem to remember there is a specific charging routine for this, so my advice about leaving it hooked up to a trickle charger is probably wrong.
The weird thing is that this is a daily driver, so holding a charge should not be an issue. I would first clean the contacts and terminals.
This guy rides almost every day. Same for me and after over 136,000 BMW miles(3 bikes) I never had a battery go bad. I did replace one near 3 years old so there shouldn't be any chance of it going bad at the wrong time. There is no reason to keep it on battery tender or charger every day.
Just my .02
One of two scenerios...
You left the key in Park instead of OFF or LOCK...... Parking lamp drained battery.
Or maybe a stuck brake light relay... That'll drain one too..
I've done it...
You could NOW have a welded starter relay causing a short that will not let the battery charge while connected to the bike...Disconnect negative battery lead from bike and connect charger directly...
Recharge battery while disconnected from the bike. You'll be fine. If starter turns when you connect the battery. Turn on the key and hit the starter button a couple times to Hopefully unstick the starter relay...
OR,
Battery is bad.... Happens... Just get it replaced and move on..
That's how a battery goes.. All at once....
Battery needs to be replaced! Some last longer than others and some need to be charged occasionally. This bike needs a full charge to start. In Florida, as an example, battery lasting more than three years is an oddity. Growing up in WV, batteries seemed to last a lot longer. Maybe those were the good old days.
I had the exact same issue even with the same battery reading and also riding daily. I called Odyssey support. I was told to buy 6 AMP Odyssey charger. In addition I added a voltmeter as well.
I think your commute is just marginal to get the battery fully charged. So over time voltage drops on the battery unless you fully charge with their charger on a more like monthly basis. Anytime voltage drops below 12.3 volts (when engine not running) I hook up the charger to the battery. I bought the charger from:
http://www.portablepower.com/odyssey_omax-6a-1b-p-801.html
!2 volt battery fully charged with a 2 amp charger is fully charged at 12.7 volts .One way to see if it is the bike would be to jump start the bike then take a voltage reading at the battery when the bike is running. The voltage should be a little higher when the bike is running.
how many miles,
Don't let SilverBuff try to take advantage of you. He's sneaky that way!!! I'll give you $600 for that busted up POS sight unseen!
Shame on you Buff! :wave
hey now!!!! we both know he don't really wanna sell it,
He just needed to blow of some steam!
I was just trying to make light of his pre-dick-ament.
As soon as he gets that thing started
he's gonna ride away smiling, and flip us both off! :)
Discussion Starter #18
I disconnected everything from the battery and charged it at 2amp for 5 hours and still nothing. Battery read 7v so it looks like its bad. My next try is jumping it with my jumper battery, after it charges up. I hope nothing on the starter has welded together. I did leave my GPS pluged into the battery for 3 days with out disconneting it. I guess that could have drained the battery. I drive most days to work and back which is 60 miles. I may just have a bad battery. Cold can zap it also. If it want jump off I'll take the battery out and take it to the battery store and see if they will swap it.
I don't really want to sell it, yet. I do like the bike. It rides great, handles wonderful and my wife like to ride on it. I know it has required much more maintenance and up keep than any other bike I've had. I don't like that part. I like to just jump on it and go anytime I want. But you guy's are funny. I really enjoy venting and everyone going with me. When it's running and I'm riding 90mph to work I want even remember being pissed off at it......
How are you charging the battery? Directly or plugged in to an assessory outlet? What kind of charger? Battery tender/BMW charger? It wont charge below certain voltage. If plugged in through an aux outlet plug sometimes you're not really connected due to dirt or corrosion.
Discussion Starter #20
I've taken it out of the bike and charging 2amps. Been on for 7 hours and I going out to check it now. I'll let you know how it goes.
1 - 20 of 21 Posts
