1 - 14 of 14 Posts
How do you quite down a noisy muffer bearing and a get volume higher on a amplified air deflector ?
Damm these LT's are complicated
In total disregard ... Scott
Welcome back my man..
I'd think that you headlight fluid adjuster drive is slipping. Add grade 7 halogen from a sealed container until it puddles under the turbo drive clutch in December.
motorhead said:
How do you quite down a noisy muffer bearing ?
Use a Metric adjustable wrench, Silly.
While your down there, check the Knuter valve ... make sure it's in line with the Giffle pin.
This is an easy one!!
The muffler bearing and amplified air deflector can be adjusted by simply lowering the input regime so that it's synchronized closer to the 4th exponential variability, and therefore matches the output of the sequential port oscillating vacuumatic diffusilizer. Piece of cake really!
Cheers, Toolman
Bouncer
The muffler bearing isn't spinning fast enough. Try removing the banana from your tailpipe to improve your perfomance.
Enthusiast - KI6CDF
There musta been a typo
Joe,
I think the "il" was carelessly deleted from the original post....
Tom
Muffler bearing issue
When dealing with a dysfuctional muffler bearing you must first assertain if the franastat adjustment is correct. This can be accomplished by applying a metric dialog to digital converting spectral meter. If the reading is in the green then you are good, if not then the widgets need to be adjusted, first the left forward one then the right lateral one and so on... You will need a specialized spanner for this operation. If you can't get it from your local BMW dealer then go to hardtoimaginethesetoolseverexisted.com and search for widget spanner/metric. Once the franastat is correct then it is a simple process adjusting the muffler bearing. This should be a straight forward job from here and once completed you should experience no more zizzing and dripping. Good luck. I will ask the moderators to include this in the Hall of Inane Posts That Suck Up Band Width.
BTW, to whom it may concern the new site looks great!
Don't listen to these guys...they're just blowing smoke.
You'll find the info you need in the BWM service manual
Section 6, pg. 6-47.
Glad I could help you,
Tbird
You will need 2' of chow line to secure the batterys of the sound powered phones, or just take it to your BMW dealer and ask them to do the 12K service it's included for free after you pay $1000!
I don't smoke, thank you.
Well, another person who did not listen. If you had just used Amsoil Muffler Bearing Grease, it would never have worn to require adjustment!
1 - 14 of 14 Posts
