They're about $95 USD per caliper here. I've been using EBC pads on my GS and the LT before that. About 1/2 price...Rockdoc said:I was more than a bit shocked to be charged 38 quid +VAT for BMW-branded front brake pads today per side. Where do you guys buy your pads from and what kind of price do you pay?
Keith
Ted Shred said:They're about $95 USD per caliper here. I've been using EBC pads on my GS and the LT before that. About 1/2 price...
They work great, have no issues. The rears on the LT are actually quiet and don't squeel like the OEM. That's why I switched originally.dkjkwood said:Ted, have you had good luck with the EBC pads? Any noticeable difference in life, noise, stopping power?
Hi, Keith - +1 here for the EBCs also. AND, I like the Carbonne Lorraine street pads - France I believe. If you use those, be sure and specify the 'street' version - not the racing version. The racing version will give bystanders whiplash when they try to locate where the banshee noise is coming from!!Rockdoc said:Thanks for the reply. It looks as if the price in the US is about the same as over here. I'll bear the EBC pads in mind for the next time they need doing.
My bike has never had the cow-bell effect. The only time the rear made any noise was when I pushed the bike backwards into the garage and not long after that began I was told I had to replace the rear disc assembly - the disc had thousands of miles of wear left but the bobbins were worn out - or it would fail the annual safety test. That was another expensive exercise.
Keith
+1 on Carbonne Lorraine (I get them from Beemer Boneyard).Dick said:Hi, Keith - +1 here for the EBCs also. AND, I like the Carbonne Lorraine street pads - France I believe. If you use those, be sure and specify the 'street' version - not the racing version. The racing version will give bystanders whiplash when they try to locate where the banshee noise is coming from!!![]()
