1 - 20 of 27 Posts
Just want to say thanks to ever said to leave bike in first gear when parking. went for ride to a uncle that was sick and a storm rolled in having a cup of coffie , looked out side and see the wind trying to push bike off stand , I THOUGHT FOR SHURE IT WAS GOING OVER ON MY WAY IN THE POURING RAIN . put did not thanks to the trans thank god!!!! thanks for the good tip!!!!
...some of us had to learn the hard way.... ;)
That is the first thing that Pete at BMW Ventura County in CA stressed upon me. ALWAYS leave it in gear on the sidestand. He said it more than once. Just remember to turn off the key if you use the sidestand to turn off the bike (when it's in gear and you put the stand down.)
Here here! I agree with your sentiments. Slow speed maneuver info was also a big help. I admit that I wuss out when executing a U-turn in two lanes. I use the go forward, back up, go forward method myself. Seems safer.
When coming to a stop I use the come to a stop and plant my foot one time method. This seems to be working for me and my lengthy 28" inseam.
All great warnings picked up on this site that have helped me keep her upright.
Loren.
I'm a firm believer in learning from someone else's mistakes! :cool:
the dealer made it a point to clue me in about putting it in gear when pointed in any way down a grade...
I learned today that when the stand is down, you can't put it in gear with the engine running.
I pushed the bike out of the garage, set it on the side stand and started it up to do a walk around and close the garage. I noticed that the with the bike running, the slight vibration had it sliding backwards (an ever so slight grade in the opposite direction) so I got on the bike to put it in gear and move it up a bit...each time I put it in gear, it killed the engine. With visions of tranny problems (read as $$$$$$$) I tried a couple more times with the same results. I looked down for some reason and it dawned on me, pull the stand up and see what happens... doh! that was it. :eek: :eek: :eek:
And that sidestand kill switch is exactly how many of us choose to shut the engine off whenever we come to a stop. And then, before leaning it over on the side stand, roll the Bike forward with the clutch out to get her against the compression of the engine, as well as giving you a few seconds for the oil to drain back into the sump before leaning it over.
The former makes sure that the Bike will not roll forward any further, and the latter will help to cut down on the smoking situation when you go to start up again!
I posted these pictures three of four years ago, but it bears repeating.
On a hot day the side stand can punch right through the pavement. Someone had moved the piece of plywood I normally use under the side stand and this is what I came back to a few hours after having parked the bike. Luckily damage was only a mirror and a couple minor scratches- thank goodness the cover was on.
Problem is, I always seem to learn more from myself :rolleyes:
I had a K100LT blow over in the wind while on its center stand while I was at work. Over $3000 worth of damage. Comprehensive covered it, but never again will I leave a top heavy bike with a full fairing like a K outdoors on the center stand.
I wish I had read this thread on Friday night!! I got up early to go on a Central Texas twisties ride with a buddy (started the ride at 0630 in the morning so we could beat the rain)!!
Back on Cow Creek (West of Austin, TX) I stopped the bike on a small country road, put the kickstand down and started to get off....then the weight started shifting left as the bike started rolling forward and the kickstand began to go back.....I caught it with a little bit of strain and the use of the front brake. I re-set the kickstand...or so I thought....whilst leaving the engine running (ok...now I know). Ran back to pick up the item that fell off my bike and as I got about 20 feet from the bike on the way back all I could do was cringe as I saw it settle onto the road. Country roads aren't the smoothest and the gravel chewed into the left black bumper and scratched the rear chrome bumper.
:kaboom:
:check: Here's the lesson, DO NOT get off the bike and leave the engine running, park facing slightly up to the center of the road where it is "crowned" (if on a country/less travelled road), and leave the bike in first gear....it'll start when you get back!
Now....a kind note to BMW....why aren't the black bumpers made of more resilient rubber rather than plastic? As for the rear chrome sidebag plastic strips....why do they have to be held on with adhesive when a good torx or allen nut/fastener would make it tons easier to change out?!! Or even better....make it metal with a rubber "bumper....it could even be color coded to match the paint (farb)!
Not sure anyone mentioned this in the thread -
After making sure the bike is in 1st, on an incline grade, let the bike roll back slightly till you feel resistance from the transmission before setting the bike on the side stand. On a "slight" decline grade, let the bike roll forward till the transmission catches before leaning the bike over on the stand... and oh yeah... always double check that the stand is pushed all the way forward... that little rascal just loves to sneak back an inch or two if you're not careful.... and reap embarrassment upon your very being.
BlauBeeMr said:
I wish I had read this thread on Friday night!! I got up early to go on a Central Texas twisties ride with a buddy (started the ride at 0630 in the morning so we could beat the rain)!!!
I'm right up the road from you in Waco. Visit the South Central forum click here for short cut ; many from Central Texas gather for RTE (ride to eat). Lone Star BMW in Austin is the nearest, trusted dealer for service.
Glad you enjoyed the ride!
Curt
I'm happy to say that ready all these posts have helped me quite a bit. I just took a trip from Ohio to Bar Harbor Maine by myself and thanks to the posts, never had an incident with the bike. When I stopped for anything, I'd put it in first gear, put the side stand down which killed the engine, took a few minutes to take gloves and helmet off (to reduce engine smoking on start up) and give everything a last once over before leaning it over gingerly to park. Guess you can teach an old dog some new tricks. Very enjoyable solo trip.
I also have to thank everyone on the forum for letting all of us newbies know about how to park an LT and where not to park. I have had my bike three weeks and absolutely love it (good bye Harley!) and have been obsessive compulsive about parking and stopping and traffic lights. I still get the feeling at some poitn it may go over but I feel pretty confident at these two "skills" right now.
I keep a round, hard plastic puck on the end of a cord in my tank bag (from my days of riding Harleys). During the summer, it's easy to lower the puck to the ground and push it under the side stand before leaning it over on asphalt. The big girl carries a lot of weight on the stand when she's healed over.
When I bought my LT last year - I was a bit concerned with the size of the bike and the weight on the side stand - The BMW dealer had a plastic BMW side stand plate on offer for a few bucks, I used it once and forgot to pick it back up!!!!
While in the UK, I came across a Wunderlicht catalogue for the LT - there are a lot of goodies in it - one of which is the side stand foot enlarger - It doubles the area of the side stand plate and is easily fitted with 3 small bolts and some thread lock. It's neat and cost £40 in the UK which is about $65.
I'm not sure if there is an importer in the USA - link to the catalogue attached.
http://www.wunderlich.de/images/International/England/Katalog_PDF/K_1200_LT_ENG.pdf
Link to UK BMW dealer who supplies Wunderlich accessories.
http://www.rainbowmotorcycles.com/WL/
Once again I learned a little something. I have a round aluminum plate I place under my side stand when in use. I never thought of drilling a hole in it and using a tag line on it. My passenger usually picks it up for me. When I have no passenger with me I find a choice spot and put her on the center stand. Simple solution nice.
If the scratches aren't too bad, there are some after market rubber strips that can be attached to the chrome guards around the bag...they actually enhance the look of the bike in my opinion and may cover up your scratches. However, they are attached with adhesive also...helluva lot cheaper than replacing those over priced chromed pieces of plastic that are a bitch to get off without a hair dryer and monofilament line...I used weed trimmer line when I replaced one. Heat the strip by applying heat from back of the case and use the mono with a sawing action.
Most of us have learned personally about the K12's "Ejector Stand". :)
1 - 20 of 27 Posts
