OK took the bike out last night and had a fiddle with the TFT and this is an update. If this sounds like a Chinese puzzle, that's because it is.
First the easy bit, there are 2 display options on the TFT screen.
This is option 1, lets call it the
Rev screen and it can be full screen or split screen. As you know the split screen on the right has 4 windows and you scroll through them using the wonder wheel.
They are, Map, Music, Trip 1 and bike computer (essentially Trip 2). You cannot program or change anything. The only thing you can change is the area in the stock picture below (lets call it User Def)
which is currently showing fuel., using the menu up you can program things like MPG, TPMS, distance to refuel, even the odometer is shown here. Only one of these can be on the screen at any time..
Option 2, lets call this the Map screen.
The Map screen is excellent for GPS information, you have the map in the middle and on the split screen you can see next turn information, the split screen shows type of turn, distance to it and I think lane information. This is the screen you want when following a route.
Now the stupid stuff, remember you have two screens and four windows on the split screen and everything else is in a menu, somewhere.
On the left hand fairing we have four pre-set buttons, non programable.
Button
1 Audio on or off, when you stop the bike audio will be muted and you need to press this again to activate it.
2 Heating menu for grips and seat, when you press this it will take you to the heating menu and you can adjust things, if you press the button again, it reminds you that you are already on the shortcut menu and that's it. You now have to navigate back to whatever main screen you were looking at. If its the Rev screen its menu up, twice. If its the Map screen you can go menu up and across to navigation and then down or you can press button 4.
3. Audio menu, same as above, change track and then start navigating to your preferred/last display.
4. Map screen as above.
How hard would it have been to allow a second press of the button to return to the screen you had on display? I can switch a light on in my kitchen and off with the same button, I don't have to go into the hallway and jump up and down three times to switch it off.
Now look carefully at the two photos above and notice even though they are split screen, the info on them is in different places e.g. gear indicator, user def button, speed. That's because the split screen windows are different sizes. The split screen is bigger on the Rev screen.
So you are coming to a stop and want to make sure you are in neutral, you look down and the "N" has moved.
Which makes me feel that the only way I will be comfortable on the bike will be by keeping it on one of these two screens. Ok, I can adjust and it will probably be the map screen for me, however, note on the map screen there is no Rev counter. So I am running the bike in and would like to keep an eye on the revs.................................
Ok, lets look at the wonder wheel, it behaves differently on these two screens.
On the Rev screen it can rotate through full screen, split screen, split window 1-4 by pushing it left or right.
On the Map screen, if you push it left it unlocks the map and you can zoom in or out on the map using the scroll up or down. If you push it right it take you to a menu and you can skip a waypoint or repeat an instruction etc.
Ok, lets say I am on the Map screen and my route is finished and instead of looking at directions in the split screen I want to see my audio tracks or I want to change the User Def to check range left etc. I have to menu up to the Rev screen (two presses) and change whatever I want and then navigate back to the Map screen or press button 4.
If anyone finds out anything different from the above, I would love to know.
To sum it up, its a bit like playing a piano with your left hand while riding a motorbike at 60+ mph.
I also know I will settle on a screen format that works for me and so will everyone else, but to do so will involve compromise. For example, when your are on the Rev screen you can display a map in the split screen., but when you are on Map screen you loose your rev counter. Why........................................................
I wonder if the BMW Motorrad people talk to the BMW car people, I don't have a BMW car, I have an Audi and it has a Virtual cockpit, pretty sure BMW have something similar.
Look up Audi virtual cockpit.
