1 - 19 of 19 Posts
Bouncer
Just added hack to resize attachments and avitars as they are uploaded to a reasonable size (avitars: 100x100) and (attached images: 620x620).
very kewlo guys. :D
That's a nice feature. I like that it creates a thumbnail and then you can choose to view the image. Is it hard coded to 620x620 for attached images or can that be adjusted to allow the image to be larger?
Just ridin'
It is like "The Outer Limits"
We control the vertical
We control the horizontal :)
Trying another image
I think I get it
THe auto-thumbnailing works for attached images only. If I embed the image using the "insert image" from the message editing dialog it gives the whole thing.
Bouncer
The current settings for image sizes are 620x620. The admin control panel allows you to change it to whatever you like.
Feel free to suggest an appropriate size.
The next hack I will implement will automatically resize inline images
Discussion Starter #15
What about setting the bounds at 800x800, which is probably the minimum screen width anyone would be running. IIRC the unwritten rule on .net is no wider than 1k.
I attached a couple of images that are 1k wide just to look at the 700 size again.
Discussion Starter #16
Hmm, looks like it took them at full 1024 width. The height was less than 700 on both; does the hack check height first, or did you change it?
Bouncer
There is not height/width setting for jpegs. I turned that off for attachments. However, I have implemented the maxwidth settings for inline images. Once they load, they will be resized properly. It's the inline images that are the big issue.
Discussion Starter #19
Ahh I got it now. Another test...
1 - 19 of 19 Posts
