For what ever it's worth I give this SW Motech DAYPACK bag 4.5 starts (out of five) it's well made, BUT pricey, and just a tad on the small size (from Revzilla) The quick release feature (fuel filler ring) works great.Anyone have experience with the "Pro"-line bags from SW Motech? Wondering which bag would be ideal for the '21 RT.
Thanks.
Marc
Not if you set it up properly! The position of the "mount plate", that gets attached to the bottom of the tankbag by you, can be affixed in almost any position. The instructions are very clear on how to do it, and you want to make sure that everything clears before drilling those holes for attachment. Beside the handlebar, DO look to make sure that the bottom of the bag will not rub on the curvature of the rear of the tank as well.Any trouble clearing the handlebars (full turn to turn) with this large bag?
Marc
The new Pro series SW Motech tank bags do NOT require any drilling at all. Look at Motor32's post (#4 above) and video. The bottom of their new tank bags has a rippled series of ridges and valleys that can run up and back to a matching set of ripples and valleys on the attached part on the bottom of the bag that sits in the fuel tank receptacle after tightening. It's brilliant, and allows you to adjust where the bag sits at any time on this bike or any other bike you own that has the same fuel ring adapter type. Just loosen four bolts that hold the pieces together, set it on the fuel ring, align to the position you want, remove from tank ring and tighten. No misaligned holes.Not if you set it up properly! The position of the "mount plate", that gets attached to the bottom of the tankbag by you, can be affixed in almost any position. The instructions are very clear on how to do it, and you want to make sure that everything clears before drilling those holes for attachment. Beside the handlebar, DO look to make sure that the bottom of the bag will not rub on the curvature of the rear of the tank as well.
I have a Hepco & Becker "Tourer M" tank bag for my 2019 RT. I find it to be "ideal".Anyone have experience with the "Pro"-line bags from SW Motech? Wondering which bag would be ideal for the '21 RT.
Thanks.
Marc
