I recently bought a 2005 LT. Immediately put on 1" down and 1 1/4" forward floorboards. later added MOP's. I find the bike comfortable, but think I need to get a custom seat that sets me back and inch or two to get more "space" for my long legs. Any ideas out there?
Bill
Ron Miller (Kontour seats) makes an excellent custom seat. One of the options is the 'tall man' which moves the rider back one inch.
I have the peg lowering kit and Ron's seat with the above mentioned option.
Helped a lot.
Good luck.
I am 6'8" 240lbs.
I still ride on the original seat, but the Bakup back rest has helped alot.... No bike is comfortable at my height ( The GS ADV has been the best... ). I have 60K on the LT and never really have any seat issues. I am 32.
Tons of threads regarding tall riders... do a little searching...
I just installed a Backup rest two weeks ago and found it decreased my legroom (36" inseam). Don't get me wrong, I like it and it definitely saved my back on a 1300 mile jaunt last weekend, but it definitely pushes me further forward on the seat than where I naturally sat without it.
Bill
I have the height problem too. I installed the XL J-Pegs for the long rides and then went with the lowered floorboards for overall comfort on long and short rides.
I ride everyday, to and from work and find the floorboards are one of the best options I have added. If you choose to go with this option, know that you will have to adjust your lean-angle in the tight turns because you will drag the boards.
Make sure you buy boards that will pivot up if you do drag them.
A back-rest helps lots too!
I've changed from my earlier comments regarding lower pegs and seat height.
I had to take the floor boards off, and go back to the original pegs. I was really digging the left one into the road way too often. It started to effect how I went in to turns, and the anticipation was not welcome..
I use the XL J-Pegs more than I used to.
I keep the seat in the higher position and have added a beadrider seat cushion (more seat height.) I used to feel the higher seat position pushed me forward, but I've been able to get used to it. Now I want to raise the bars..
These changes work for me.. (6'5" 230)
Jeff
I didn't like the lower pegs because of corner scraping, so everything is stock. But when on a long trip and no one is around me I will just slide back to the passenger seat. That sure is a nice seat back there. The only bad part is you sit up higher. It gives your arms and legs a good stretch though.
But then I am only 6'4" and consider the bike at just the right point. Sat on countless Harleys, and always found my knees were above the gas tank, thus I felt like Herman Munster. Sounds like some guys here out Herman me.
Never liked that the american seat has less padding than the european version.
