I went for a ride last night after work and all was well for 50 miles or so. On my return trip, I started having issues with high beam not coming on after dimming for oncoming traffic. At first it was slow to respond. I would leave it off for about one minute then trying again, would fire right up. Eventually, it stopped working altogether.
Is this symptoms of a failing ballast? Or a failing connector somewhere?
DDM Tuning, 55w, 5000k, H3.
I would go towards the ballast as I have an HID install that is 10 years old and it started getting flaky a few years ago. Traced it to an inline fuse that was corroded. But two years ago it would not always light up the first time. I replaced the ballast with a good Phillips unit I pick up at CCR Silent Auction. It now fires first time every time and is a bright as ever. Same 10 year old bulb by the way.
I'm willing to bet "Ballast" as well. The guys at DDM Tuning were real good about the warranty (was only about a year old), and sent me a whole new unit (bulb and ballast) just to make it simple.
We all guessed wrong. Took delivery of new system a couple of days ago and finally got a chance to install earlier this evening. Connected the new ballast first, but no-go. Replaced the light element and now all is good. :wave
Just curious was the quartz globe broken inside the tube? Usually the bulbs will go a long ways, unless broken. Glad you fixed it either way.
