Does not have diagrams available now, but the original radio gets powered always when the ignition switch is not in the steering lock position. So there is not "switched connection" available to radio. If I would need to build such, I would use direct connection (using fuse of course) from the battery through the relay controlled by rear-seat heating connector (there is switched connection).
Seppo
Seppo
