I have a 2005 non-esa RT, so I am just wondering if there are any general settings for riding 2 up and also riding 2 up fully loaded?
When I ride solo I have the spring preload and damping in the normal position.
I weigh 85 Kgs and my wife weighs 60 Kgs.
When my wife comes along and when we bring luggage, I dont know how much to adjust the suspension, so any advice on general settings would be appreciated, without getting too technical and having to take various measurements?
We have a non ESA 2006 and ride two up fully loaded most of the time. When I say fully loaded I mean both side and top cases. We usually keep stuff in the top case and a small cooler (summer time) in the side case with a few tools in the other case. Not all the time but some of the time we also pull a single wheel Unigo trailer. As far as the shock adjustment its close to it's upper limits. I have really never adjusted the thing since we first got the bike. I would say also that what adjustment you do would also depend on the road conditions. If your on a road that's really bumpy and you have it set to soft you could bottom out. What I have it set out now we've never had a bottoming out issue and the ride is smooth. I weight about 200 and my SO about 110 pounds. When I first got the bike here's what I did. I ran the adjustment down all the way and then counted the revolutions it took to get to the highest setting. I don't remember how many it took but I think you get the idea. If it took 20 turns to get to the highest setting than 10 would be half and so on and so on. Hope this helps.
I also have a non-ESA 2005
When I get ready for a more heavily loaded trip, 2-up and lots of baggage, I crank in about two more turns on Preload. After the trip I return it to what I call "normal".
In either case I am looking for a setting that does not have a lot or bouncy rebound from bumps and undulations in the road surface nor a harshness.
You might have to experiment some to find your happy spot and then deviate (adjust) from there.
Discussion Starter · #4 ·
Thanks hopz, what about the damping on the shock absorber, would you turn that clockwise much with the screwdriver?
I have mine in the middle and have never felt/sensed the need to tinker with it.
I have to admit that I have a difficult time with setting the shocks... those that can be adjusted. I read all the arcane literature and my head glosses over.
This is just for me... but I put the dampening in the middle and fuss with the preload. so far it works for me.
