I did a search, but I didn't find what I was looking for.
I just got a battery tender jr. Following the instructions it says connect the positive to the positive battery post (this is assuming that the negative is attached to the frame, which I am assuming the 2000 K1200LT is) and the negative to the frame. OK, I get that, but I've seen a lot of motorcycles that have both clips attached to the battery. It also says that if you take the battery out of the motorcycle you attach the positive to the positive and the negative to the negative. Why is that different?
The other question is in the manual it says to remove venting caps, etc, but you don't do that if you leave the battery in the motorcycle.
I guess my question is, I want to hook up the battery tender when I am done riding, but I don't want to remove and install the battery every day. How do I go about doing it safely? I'm not sure what type of battery I have, I can't get one of the screws out of the top bar that holds the battery in place. Any suggestions?
I also lost a washer that goes between the two red rings that connect to the positive? I'm assuming it is ok to run it without it until I get another one?
