02 RT with 22,000 miles. When I bought it, it stumbled and died every time it settled at idle unless I kept up the revs. Then I did all this:
- Installed PC III (was told it wasn't necessary, but I'd already bought it)
- Adjusted the valves
- Tuned the throttle bodies
- Replaced spark plugs
- Replaced fluids
- Ran Seafoam through the tank
The problem went away and the bike got a lot smoother, but now the stumbling has returned. It's not as bad as it was when I bought the bike, but here's what it does:
- Every once in a while it skips a beat at idle.
- When it heats up a bit, it skips a couple beats and then dies.
Idle is set to 1100 RPM, 1500 RPM with choke.
Have any of you had this problem before? Any ideas what could be causing it?
ape
- Replaced fluids
ape
