· Registered
Trying to check valve clearance. Removed all bolts & tapped with rubber mallet like it says in Climer manual. But it's stuck!
I don't want to pry against the head.
Any ideas?
Thank you!
· Registered
Be absolutely certain you got all the bolts, including the 1 towards the front in the centre of the cover between the cams. It should just let go as the rubber type seal is ribbed and normally doesn't adhere to the cover (in my experience). If it is stuck however, just insert a screwdriver at 1 corner and gently twist, do not drive it into the joint or the alloy will be damaged along with the sealing rubber.
· Registered
Discussion Starter · #4 ·
Well, I had all the bolts out, just needed to give it a little twist with screw driver at the edge & it came free.
I did find 1 really tight intake & about 6 other clearances that are tight.
Might as well get it done now while it's still snowing here...
· Registered
"Tight " meaaning tighter than minimum spec I presume, that being the case, it's important that any tight exhaust valve clarances get addressed as a priority (burnt exhaust valves not good). So it's front engine cover off and cams out for you. Document all the (16) shim thicknesses and their positions for easy calculation of future new shims or position swaps.
· Registered
Discussion Starter · #6 ·
Dennis,
Thanks for the input.
yes, I have 5 exhaust valves below min. I plan to pull them tonight & see what I need. I hope I can move a few around....
I went thru all maintenace records & do not see where valve clearance was ever checked & no lifter $ ever show up.
After 68k miles I surprised it's not worse.
I plan to keep this bike for many years. My 1992 K1100 LT has 135k miles on it when I solder her & she still ran like new!
· Wrencher Extraordinaire
K100Dennis So it's front engine cover off and cams out for you. [/QUOTE said:
No need to remove the front engine cover, just the valve cover.
