1 - 9 of 9 Posts
I stripped the clutch ventilation hex screw head when bleeding my clutch last weekend. Thankfully I was able to bypass the stripped head by watching Kurt's clutch bleeding video. I was going to reorder another one from Max BMW (part #: 32 72 2 333 158, VENTILATION SCREW) until I saw it cost $46.67. I didn't see one listed on Beemer Boneyard. Do you all know of another source for the part that may have a more respectable price?
Rob, 2000LT
Navarre, FL
Rob, 2000LT
Navarre, FL
Bobby, I have heard of at least one person ( did not see pics) who removed the ventilation attachment and replaced it with just a speed bleeder screw on the end of the hose. It is probably on with locktite so some heat might be necessary to remove it easily.
I know this can be done on the front caliper and the attachment is the same.
Reactions: Patric
Yes you can remove it (use some heat) and go slow as there is loctite on the threads. Replace with conventional bleed screw.
Reactions: Patric
JZeiler, when you say "conventional bleed screw," are you referring to a bleed screw like those on the brake calipers? Is there a specific size to ask for?
Rob, 2000LT
Navarre, FL
Rob, 2000LT
Navarre, FL
The BMW part is
34 21 2 330 310 VENT SCREW - M10 $10.95
I believe it is a 10MM bleed screw.
The BMW part is
We have a WINNER!!!! You can find them at auto parts stores as well.
Reactions: johnbaker15
I did just that on my '05. Makes it a breeze to bleed clutch. Heat the fitting and remove it, attach the SpeedBleeder in its place. Done.
1 - 9 of 9 Posts
