Enjoy The Ride
I'm going to by a wheel balancer soon & have been trying to decide between a static or a spin balancer. I have a static balancer for the LT wheels. The static balancer is slow & on one of my rear wheels I have two heavy spots :think: . The blue painters tape is where the heavy spots are. Does anybody here have any experience with spin balancers ?.
I have a Snap On spin balancer. It works very well and is easy to use. I also have a static balancer, takes a little more time but also works well and is a heck of a lot cheaper. If your a tool freak like me a spin balancer is a must. If you're more practical and just want an accurately balanced tire the static balancer is the way to go.
I have been using the 'Marc Parnes' static balancer for 4 years. Its packable, very well made and super accurate.
Works with a variety of M/C wheels. You order specific adapters depending on your bike.
http://www.marcparnes.com/
Why do you have two heavy spots in the same plane? They should combine and register as one heavy spot since they are in the same plane. This is a static balance situation. It suggests your wheel balance may be very close without any extra weights.
A spin balancer (called a dynamic balance) can detect out-of-plane balance problems - requiring two weights on opposite sides of the rim, although this isn't always necessary.
+1 Marc Parnes is an excellent product.
Enjoy The Ride
One of my jobs at Penske racing is balancing the engine assembly. I have been using spin balancers on engines & tires for about 40 years. The two heavy spots are 13 inches apart. I suspect they are out an equal amount of weight. On static balancers I always rotate the heavy point 90 degrees each way to see if returns to the same spot. When I mount the tire on this rim I'll put the orange dot in between the two marks.
Enjoy The Ride
+ 1 on the Marc Parnes balancer here too. I don't change tires that often so the MP is ideal for me.
Super Moderator
Sorry I do not have a recommendation for a spin balancer and like many here use the
Marc Pharnes.
In looking at your set up I would have a few questions:
- can you move your supports more towards the wheel to reduce the shaft bending
moment. See of the heavy weight points move if you try to do this.
- does your balancer allow you to turn the wheel around
- have you checked to see if your wheel runs true - less than .010 run out
- how confidant are you that this static balancer is centering up your wheel
There really cannot be two heavy points - its your equipment inability to be precise.
If I could justify the $$$ I would definitely go for a spin balancer - just can't justify for a
tire a year!! :(
