1 - 2 of 2 Posts
finish putting injectors in. put 1 1/2 gallons of super unleaded gas and fired lt up. engine turned on right away put engine is sputtering like if there air coming in. checked all lines everything is connected. can it be that there is only low fuel in the tank? and then you put the gas cap on does it has to click like on a car.....
Don't worry about the gas cap.. Removing it is a troubleshooting step to see if the vent line is clogged... It shouldn't make a difference..
See your other post about resetting the TPS
1 - 2 of 2 Posts
