My labour started with trying to track down why my cruise control didn't work. Got her stripped down to where I was supposed to take the air box off to get at the micro switch. Couldn't figure out how to remove the airbox. So, I started poking around and discovered that when the tech put her back together he installed a wiring harness, it pushed the throttle cable down. That's why, after I spent hours trying to adjust the throttle controll cable, the cruise would not work.
I got the tank bac on, most of the tupper ware back on except for the fairing on the brake side, and tried to start her. After a long time cranking, she tried to fire, but wouldn't start. I thought I might have mixed up the fuel and return line to the tank, so I swapped those around--still won't start!!
I'm over tired, ffrustrated, and looking for help?
I shone a flash light into the tank, almost full, and didn't see any movement in the tank.
I know I connected the wire at the top of the tank and at the bottom. But, I'm not sure I hear the fuel pump working? Course, I don't remember if I've heard the fuel pump when starting my bike?
Looking for any tips, suggestions for tracking down why she won't start.
Best from Becket MA
Bob
PS: while I remember it, the tank has two lines comming off, one nearest the bike and one next to it near the outside of the bike. Which one is the pumped fuel? The lines going to the fuel rail are one on top of the other--which one is for the pumped fuel?
Oh! The internet connection here is dial up.
Best from Becket MA
Bob
