As the title suggests my sprag clutch isn't engaging. I've already tried rislone, as well as removing the crank case cover and cleaning the assembly with carb and choke cleaner once and kroil another time. I've rocked it backwards in gear and tried starting to no avail. Next step is replace!
Questions:
1) I just replaced the clutch last year so I know what I'm in for but would it be easier to pull the engine instead?
2) What is the parts list for sprag clutch replacement?
3) Since I just replaced my clutch are there any parts that I won't need i.e. Rear main seal, crank nut, flywheel bolts?
4) Is it necessary to replace the entire sprag clutch basket, or could I just replace the sprag wheel with the teeth (term?)?
Thank you!
Questions:
Thank you!
