1 - 3 of 3 Posts
It continues to amaze me the amount of serious information that exists here. My speedometer was intermittent for awhile, then finally died. On a related note, my cruise control was acting up at the same time. (Duh!)
Today I did a quick search, found an entry by Dave Shealey saying with certainty that if the bike was 2002 or older, it was a broken speedo cable tied to the brake line. I pulled the plastic off (which was the hardest part) and sure enough there was the culprit. Actually the culprit was the guy that had this bike before me and did a crummy job fixing it the first time. I soldering in some new wires, bolted everything back together and everything works.
Thank all of you that contribute so much. I'd either be a lot poorer having to take it to the shop each time or it would be sitting in the garage instead of crusing the highways.
Thanks again!
Nicely done! You can get by without the speedometer but not without the cruise control. At least that was my experience.
Loren
A big thank you from over here as well. My speedo just kept bouncing like a basketball, and I was like..NOOOOOO, not my baby!!!
That is what brought me as a new member to this forum.
However....
My first search on the speedometer issue...I got hit with posts that this is often a precursor to final drive failure :confused: :mad: :( I went through all kinds of emotions over that...lol.
Then, I finally landed on an old thread with Dave's input about that notorious zip-tied-to-brake-line wire damage. 45 minutes later...with soldering and two layers of shrink tube, the second having that gooey sealing property to keep out the water, and I was singing the praises of people like Dave and forums like this.
Is there any way to create a STICKY for such a common problem as this :wave
1 - 3 of 3 Posts
