Does anyone know for sure what the part number is for a speedbleeder valve that will fit a 2001 K1200LT w/ABS? I want to replace the old bleeder valves on my LT, but I cannot find any information on this forum regarding the correct part number(s).
speedbleeder.com shows a part number for 1996 and up, but I do not know if that is a universal part number for all BMW motorcycles? I spoke to one of the sales reps, but he could not tell me for sure what the part number is for a 2001 K1200LT. However, he did say that I could measure the thread size of the existing bleeder valve.
I don't want to dive into the brake system just yet, weather is too nice at the moment in ATL, unless there's no other option for determining the correct thread size/part #!
This is the web information:
BMW 1996 and after
M10 X 1.0 front Part# SB1010S
M6 X 1.0 rear Part# SB6100
Thanks for your help.
Jose
What kind of calipers are on your bike. BMW or Brembo..
I think the first one is the correct one. M 10 X 1.0
SB 1010 S is what fits my 99.
Does yours have the linked brakes ? I'm not really up on the time when the brakes changed, seems like it was 02...I think your 01 is the same as my 99
David Shealey will chime in here in a minute or two and tell you for sure.;
Don't forget to heat the caliper and clutch line to remove the bleed adapters and install the speedbleeders... Otherwise you'll likely mess up trying to remove them...
Good Luck
John,
I have Brembo calipers, but I don't know if they're linked or not? How can you tell?
I read a previous post that mentioned..."This is the first of a couple of articles on brake bleeding. This covers the non-linked ABS brake system which was standard before 2002." The article has great instructions on how to replace the bleeder valves.
Thanks for the tip about heating the calipers!
Jose
IBR# 366
If the calipers say Brembo then they're not Integral (linked). If they say BMW then you have the newer Integral brakes.
Ken,
Thanks, now we know they're not integral.
The question still remains on the part number for the speedbleeders??
Then the pN is the SB1010S.....That'll work for you.. You'll need 5 if you also do the clutch. I highly recommend them they turn a difficult job into a 30 min breeze..
Once installed that is....
JOhn
My 2001 used SB1010S --- I got 5 of them and also purchased the speed bleeder bag and hose combo.
They work like a champ.
Thanks John and Paul for your input.
...I can now get this task completed!
