Car toys. Best Buy. Crutchfield. Buy cheapass 5.25" plastic cone speakers and be done with it.rortiz said:Does anyone know a place where I can get some rear waterproof speakers for my LT?
:wack: THAT is insane!! with the right amp you should be able to compete with the air raid sirens.Vic said:Just completed 8" Rockford’s M2 marine grade M282B.
Need mod your existing place for speakers>
Better check your mpg with all that increased wind resistance :histericaVic said:Just completed 8" Rockford’s M2 marine grade M282B.
...but what you DID NOT see in this picture is Vic's new riding outfit: :rotf:Vic said:Just completed 8" Rockford’s M2 marine grade M282B.
Cochinosucio said::wtf:
Now all you need is some 50 cent pumped up....
With alpine ALPINE SPR-50C 5-1/4" 2WAY COMPONENT SPEAKER SYSTEM in frontbeartooth said:Better check your mpg with all that increased wind resistance :histerica
This is cool, is that gps original from BMW? We dun get that is Singapore ...Vic said:Original BMW Becker will cause problems every two year & very expensive in consideration of its functions.
Wow...where are you going to mount the sub woofer?Vic said:Just completed 8" Rockford’s M2 marine grade M282B.
I put those Polk in both the front, and rear. For them to fit the rear, you just cut of the screw prongs, then mount them in the factory rings. To put them in the front, all you have to do is cut, drill, screw, tape, smash, curse, curse, curse, drill, screw, re-assemble. :histerica Even with all that work, they still put slight pressure on the dash. TIGHT!!!rowie said:I haven't done it yet but me and a buddy I intend to put a pair of Polk Audio DB521 speakers in the rear. Others on this forum have done it and the sound improves substantially according to them. And these speakers are marine grade so they're fine in the rain. Hope this helps!
