1 - 20 of 24 Posts
I have seen many posts discussing if and where to carry the plastic spare key when out and about. Some say in their wallet, others give it to a fellow rider and others just leave it at home (praying they don't need it this trip). And others have said somewhere on the bike but then worry about where and if it will be safe. Under the seat is useless as you would require a key to get to your key. Here is my suggestion and you can take it for what it is worth to you.
First, I don't want to carry it in my wallet for a host of reasons.
Second, I want it on the bike and I want it safe.
Third, I also want it easy to get to so I'm not spending a lot of time trying to retrieve it.
I stumble across this location when I disassembled the front headlight assembly to swap out the bulbs for LEDs.
It is well hidden and if you weren't reading this post you would never know where to look for it. One can only hope that by posting this info it does not cause folks to go around checking every RT out there for a hidden key. That said, I believe most folks are honest and I have good insurance so if there is a scumbag that reads this and finds my key and steals my bike :mad:, well that means it's time to upgrade. :)
I am attaching 3 pictures which should tell you everything you need. The location is discreet, secure and easy to get to.
172015
172016
172017
Again, this may not work for you depending on your paranoia level but for me I always have it available if/when needed in a secure location that is easy to get to. YMMV
When touring with another rider, I always give them a spare key to my bike. I don't lose keys very often, so I've never needed it, but out of all the few things a rider should have two of, keys are on the top of the list.
'20 R1250RS, '87 VFR 400R & '18 Alfa Romeo Giulia ti Lusso..
Excellent. Thanks for the suggestion.
2015 R1200RT
I put mine in a mini plastic ziplock type bag and hide it under the rubber on my footpeg . Works perfectly and takes about 3 seconds to access
Reactions: Hfjeff
I'm a bone head, never new the mirrors folded in lol. Went to go check and it has a string in there already, wonder if dealer must have used that area to hang sales sheets or something. But great idea thanks!
Hiding a key in the mirror housing seems like a slam dunk, but be careful! Thrice (in 6 years), my mirror housing has opened on its own -- first time was the result of a zero mph tipover, the second time when bumped in a parking lot, the third time while cruising on a "shake'n'bake" road, at about 55 mph.
Be careful -- don't lose that key!
Discussion Starter · #7 ·
Yep, that's why I suggested attaching it to the string so if for any reason the mirror were to open, it would remain attached and not fall out.
The all have a string in there, it’s a tether to prevent losing the back cover on the mirror which is removable. The OP used a small key ring to attach the spare key to it, it would not be lost if the mirror folded back or the cover came off. An outstanding idea my complements for sharing it
Sent from my iPad using Tapatalk
I note the picture of the mirror in the closed position. How do you get to the open position? Thanks for your help.
Discussion Starter · #10 ·
Just pull the mirror back towards the rear of the bike. It folds back just like most car mirrors.
Discussion Starter · #11 ·
Discussion Starter · #12 ·
To be clear, pull back on the entire mirror assembly, not the mirror itself. :)
Yes, pull back by placing your hand on the outside of the mirror housing. It'll fold back and toward the bike.
Mine is in a magnetic "safe box" that sits on the "ledge" behind the front fairing side panel
172039
Product Lens Electronic device Technology Line
Have you checked to be certain that storing the plastic emergency key so close to a rare earth magnet will not cause issues with the data I believe is contained in the plastic emergency key? I'm not entirely sure how that emergency key works other than it must be in direct proximity to the dash.
It's been sitting there since last March.
I tried it today and the Bike turned on right away.
No issue for me
No issue for me
Pretty much what I would expect, but I would also have been quite cautious! I believe that what's inside the plastic key is RFI technology, like what we have in our contactless creditcards nowadays. Those are not affected by magnetic field.
1 - 20 of 24 Posts
