LT is gone to others and a few maintenance parts remain . . .
This modified 30mm socket and 12mm hex wrench combination are designed to remove the pivot pin on the swing arm.
The keeper bolt needs to be tightened to 160nm while holding the pivot pin from rotating.
Asking $15 and you pick up whatever the actual cost to ship via USPS
Package weighs 1lb 5 oz and is 5 x 5 x 3
This is a drill and "slave cylinder seal set" used to:
- drill the weep hole with the set used to accurately place a replacement seal at the correct depth in the transmission housing
Asking $10 and you pick up whatever the actual cost to ship via USPS
Package weighs 6 ounces and is 6 x 5 x 2
Buy both and I will put in a smaller box to save on shippng
PM me if interested . . .
Dan
Dan
