I have removed the clutch push rod from the transmission and inserted the outboard end into the slave cylinder receiver (thrust bearing?) to check the fit. There is a fair bit of side to side and end play between the inner race and bearings of the thrust bearing. Not having this apart, I am not sure I am describing this properly, but I am sure the play is not from the fit of the clutch push rod and the 'receiver' it fits in on the clutch slave cylinder. Is some wear normal here or am I into signs of a thrust bearing failure and replacement of the slave cylinder? The bike has about 30,000 miles on it.
