What is the size allen wrench do I need to take the drain plug out of my tranny 09k1200lt
wa1200lt said:I bought a regular 9/16" hex wrench at my local Ace Hardware store. Cut about 2" off the long end and glued it into a socket.
There is room for the ratchet once you remove the exhaust hangar.
You will need to have a hex socket in order to torque down the plug if that is your plan.
You will also need a 12mm hex socket down the road so the set of three at Autozone would be a good bet.
Have fun,
Loren
My first fluid change, I didn't have one. A 3/8" rod coupler (has 9/16 o.d. hex) is available at many hardware stores. Just drop it into a 9/16" or 14mm socket.wa1200lt said:I bought a regular 9/16" hex wrench at my local Ace Hardware store.
Loren
The Autozone set is a set of 3, 12mm, 14mm, and one other size. Can't remember the size, 16mm maybe. Seems like when I got mine a couple years ago they were $10.00. I suffer from CRS. That, and it's something I HAVE to have, so I buy it and don't think about the price.pauleknight said:I am curious as to the Autozone "set" how much and is there a part #
