1 - 1 of 1 Posts
recap... new Siebenrock failed after 12 miles, clutch would not disengage. Removed clutch again..... Clutch is not flat,,, outer and inner edges are higher than the middle. You will notice the light under the straight edge. If you look at the pressure plate the outer and inner edges are scorched but the center is untouched. With the clutch plate only making contact with part of the pressure plate is was not "hooked up" and was slipping yet not very noticeable,, heated up and turned the plate material to mush and bonded to the plates. Still no word from the clutch camp. Installing stock plate tomorrow.
1 - 1 of 1 Posts
