1 - 20 of 20 Posts
Yesterday I was riding on US 441 from Gainesville (FL) to Ocala. There I was going to get on Interstate 75, take that to the Turnpike and head home here to the southeast coast, planned to be about a 4 hour ride. As I enter the southbound on ramp to Interstate 75 I began to upshift. Get in to 2nd gear OK. Now, the shifter doesn't seem to be shifting. I look down and the shifter was looking pretty limp. I get off the interstate at the next exit, pull in to a gas station and remove the side cover of the LT. Shift linkage ball joint sheared at its connection. No roadside repairs here. I call BMW of Daytona Beach (they were the closest as 78 miles away); they had the part(s) and gave me directions to their shop. I did enjoy a leisurely 35mph ride in second gear through the Ocala National Forest and arrived in Daytona 2 1/2 hrs. later. Kudos to Daytona BMW. Fixed my LT quickly and I was on my way home. The ball joint was $4.50. And about 700 miles ago I did my 24k service; checked the linkage as part of it and all was well. Always have a BMW dealership (or two) telephone number programmed in to your cell phone!!
Get the new, improved, and beefier linkage.
I forget whoi bought it from.....a member of this site..................
someone else will remember or do a search................................
A much stronger product than BMW
Beefier is maybe not a real cure
My concern with a beefier linkage is possible damage to the transmission. Several people, including BMW shop people have alluded to the fact that our shifter is sort of like a fuse. I carry spare parts, but have hesitated to go with anything stronger than stock.
2011 R1200RT
[email protected] I bought 3 of these kits and love them!
yes,....philjohn
great product...but don't forget the locktite.
Re: Beefier is maybe not a real cure
I'm w/ Dan on this one - have to believe that the BMW engineers designed the shift linkage the way they did for a reason.
THAT'S IT !!! You guys are geniuses !! :eek:
The BMW Engineers designed the Final Drive to disintegrate in order to save wear and tear on the rear tire !!!!! :D
I just knew there was an unknown reason for the Final Drive issue !
Yes they did design it for a reason it is called cost saving. As one engineer told me if it does not break then it is build to heavy make it lighter until it breaks then add as little as possible.
That's right - and don't forget where you heard it first!
Be careful not to void your warranty(if you still have one) with the beefier part. It's considered aftermarket, not BMW recommended, and if nothing else is an excuse to deny a claim. You can also get charged up to an hour of labor if service has to disconnect the aftermarket unit from the tranny. I waited until my warranty expired to put on the beefier model. My original OEM linkage broke under warranty. I carry the second OEM as a spare. :rolleyes:
IBR# 366
I'm curious: exactly how did you "check the linkage"?
At every 12K service, I would pull the foot peg plate, remove all the linkages, tighten all the ball studs, grease everything, then put it all back together. I was already in there doing the service so the extra work was minimal, and I never had any problems after that.
I agree with Ken.
Service the linkage regularly and you'll not be having any issues with it.
I do mine about every time I change the oil. 6K.
Now, If you shift it with your entire leg/foot then it's going to break anyway.
Shifting the LT is like a little dance. If done correctly it takes MINIMAL force.
You should almost never have to bang on it. Only in a panic situation have I ever beat on the shifter. Just a slight toe lift and a quick tweak of the clutch and she shifts like butter...
Wow, another LT rider in my neck of the woods. When my ball joint broke off the remaining threads were a bear to get out, and had to get a new ball and receiver-thingee (technical term I know). Was tooling around in 2nd for a couple of weeks while a BMW shop did warranty work via the post office.
If you're going to be stuck in a gear, second is the best one. You can't use your center stand that easily, but can go from a red light up to 60 or so.
Although I don't have one yet, I think and have heard from others these are a good upgrade to the OEM. However, not much help when the bolt from the shift pedal to the tranny linkage shears...which is what happened to me. Add a cordless drill, EZ Out, and another bolt to the tool kit!
PIA!:mad:
2011 R1200RT
PIA!:mad:
Actually a reverse drill bit and an EZ-Out are included with Phil's kit. This is not intended to be a roadside repair kit, it is a shop repair kit, or a proactive upgrade kit, depending on when you use it.
2011 R1200RT
wacolt said:
You mean these from PowerGrid? Linkage kit
ebay link clicky here
I don't have a picture of mine with me, but I'll try to post later tonight. Phil's kit is a bit different and only includes the longer linkage as it is the one that tends to break.
Why not manually shift the linkage into at least 3rd until you can get in for service. Carry a spare ball stud (takes up very little room) and a couple of tools in your kit for a roadside repair the next time it happens.
CAn you say the same thing about the F/D unit? ;)
I tried that when my bolt sheared...was finally able to get it into second and crip home.
1 - 20 of 20 Posts
