I've learned of peg lowering kits for the K1200 - I'm 6'1"+ and wondering if there are short/long peg extensions AND if it necessary to get coordinating extensions of the shift/brake levers as well????
I put peg extenders on my old LT and was amazed at the difference -- am wondering if there is that much of a difference on the GT?
- Stephen
IBR# 366
Suburban Machinery makes a set of peg extenders for the GT, as does Verholen. I put the Verholen 40mm (1.5") peg extenders on the day I got the GT. The SM extenders are fixed, but the Verholen extenders are two-piece with a serrated interface which allows a bit of fore-and-aft adjustment if needed. But I found that once they're set you don't really need to move them.
With those and the seat in the high position I actually had slightly more leg room than the LT. But it's much easier to drag the lowered pegs in the corners, so if you're an aggressive rider then you might want to consider that.
Verholen also makes a 60mm (2.36") adjustable passenger setup, sold through Pirates' Lair. They would be a bit too much for the driver though, as they would scrape even more than the LT does. :D
You can get shifter and brake extenders, but I haven't really found them necessary. Even when I add or remove the peg extenders, I find that I adapt pretty quickly.
Other folks say that the peg extenders put your feet just a little too wide, so that pedal extenders might help them. It's really an individual call.
I have also toyed with making my own peg extenders that bolt onto the GT's frame, thus being able to keep them tucked in closer to the existing peg width. But I don't have a workable prototype yet, and that damn brake lever is in the way . . .
- Stephen
I have the Verholen peg extenders, and would find it hard to live without them on very long rides. For local riding, I prefer them off.
With the Verholen peg extenders, your feet are placed wider, so you must turn in the fronts of your boots to operate the shift and brake levers. It becomes natural after a short time, but it is different than the standard shifting and braking positions.
I also own the corresponding Verholen shift extender. It is a cylindrical tube that pushes on over the shifter, with a set screw to hold it in place. I don't like it, and haven't used it since I bought it. The reason I don't like it is that it is thicker than the shift pedal peg - after all, it has to fit over the shift pedal peg. Because it is thicker than the original shift pedal peg, you must twist your ankle further up and down to get your boot over and under the extended peg. I may give it another try someday.
In addition, the original owner complained that the knurled pattern etched into the outside of the shift peg extender was abrasive on his boot, so he used a grinder to smooth the sharp points of the knurling pattern on the peg extender.
I do not own the brake extender.
Thanks guys!
The verholen's are a bit pricy; however, I do like the ability to adjust - and it's a BIG plus to learn that you got more length on the GT than on the LT!
BTW, just replaced the stock windscreen last night - wow! - what a difference!
Stephen
IBR# 366
The adjustment really only happens once, when you first put them on. After that, they pretty much just stay in place.
What windshield did you get?
Regarding your original question about shift and brake extensions, you can easily adjust the height of the gear shift lever to match the lowered pegs. Like XMagnarider I bought the shift lever extension also and I no longer use it either. It tore heck out of my boot and found I could easily enough hook the regular shift lever with the side of my boot once I got used to it. I did buy the brake pedal widener which slips over the original pedal. I like it. You cannot readily adjust height of the brake lever but found it was easy enough to adapt to.
BTW, I got the tall V-Stream windshield and really like it.
Sorry for the slow reply - time flies when you're in the garage working on the new toy! I got the large Ztechnik VStream - what a difference of that stock unit!
