I have never seen this before. I'm going to have to try it !
My low fuel light has never come on, even when I drain the tank.
This kind of info is the good stuff. (too bad no more How updates)
Great find Howard.
Leave it to the GS-911 boys to find a solution. I reviewed the schematics for 99-2009 and although the electronics is different between the 99-04 and 05-09, the same signal name is on pin 3 so it should work on all model years.
Best part is you don't even need the GS-911 to do it.
What does "Non'Can" mean? :bmw:
Non Can means non "canbus" or bikes with conventional wiring harnesses. Need to check your manual to know if yours is or not.
All LT's have conventional wiring harnesses.
