srpuywa said:When I put the seat in the high position and sit down, it flexes and slips down past the lock. Is this a common issue and how can I fix it.
After leaving your place, I went out to 18E and got off at the next exit past Auburn....and stopped at Gree Valley Meats for a big piece of Langerwerster (or something) and a Diet Mt Dew and got to thinking about that bar under the seat.........and I'm thinking that if you removed that whole assembly, took it to a machine shop and them weld another piece of tubing to the INSIDE of each of the factory ones, you could extend the length and better be able to get the whole thing to drop in the grooves like it's supposed to do. Of course, grind down any of the excess weld material.......and paint it....put it back into place. How about finding a chunk of hard rubber block (3/4 or 1inch) ought to do it....cutting it to fit on the frame under those rubber bumpers.....and glue or zip tie them to the frame......help to keep the seat from flexing so much.srpuywa said:I sent you my address and cell,
All right.....let me know how they work......srpuywa said:I think I'm going to make some bumpers to add to the frame for now - thanks again
Scott
