I'm about to get with some buddies and drill a weep hole in an '02, an '03 and an '05. I'm trying to figure out which seals to preemptively replace, but having trouble figuring it out after much searching around (and therefore which part numbers to order for all three bikes). Would anyone know?
I also on my '05 have a very small oil leak on the top of the rubber boot - basically it's not enough oil to do anything other than create a "dusty" kind of coating that can be wiped off with a finger without leaving an oily residue. But if I'm in there I might as well sort that out too - any idea what seal that one is (and then I need to find a part number)?
Lastly the link in the sticky weep hole video thread that is supposed to be a procedure takes you to a PDF of a recall document for the alarm etc on early 05's. Does that procedure document exist anywhere?
Thanks guys!
Thanks guys!
