1 - 9 of 9 Posts
My shifter went on me today three blocks from home talk about luck was planning a good day of riding and not close to home, but I do carry the replacement parts.
This is my first time to replace it and doing a search I can not seem to find a step by step how to do the work, did I miss it, can anyone help I have the side plate off, do I need to remove the tupperware on that side top and bottom?
I did see that people have found a heavy duty kit which I will likely go for after this, although I have 70,000 on the original but I also lube it on a regular bases.
Depending which stud broke you can access all linkage with removal of the lower left fairing. suggest you check all links .
Here Bruce:
http://www.bmwlt.com/forums/showthread.php?t=20134&highlight=linkage+repair
This should get you on yur way. BTW I never had to remove any tupperware but others say it is easier.
Hey Bruce, mine came off twice before I put a heavy duty one on. No problem installing it, I did it in a parking lot with a 10mm wrench and a pair of needle nose pliers. Took about 15 minutes. No need to take the tupperware off, just the side plate.
Garry
Same old Shifter linkage
Thanks Guys
I have it all apart and find that some *&^$ forgot to use Lock tight on the on of the important spots, so guess what it fell apart not broken and did only a little damage to the threads, so I am replacing everything just the same and keeping the parts that are in good (used shape) as emergency parts as there is very little wear in most of them.
I see what you say about taking it apart the only thing to slow me down way the amount of grease on the linkages.
Cheers and safe riding
Ace Hardware Rules!
Just a story to give everyone hope when your linkage breaks as far away from a BMW dealer as you can get..... Mine went out on a vacation trip , no dealer in site, on Sunday. At best I was looking a three days lost. I found out that Ace Hardware carries a line of curtain rod swivel connectors that will duplicate the shifting connection. That bailing wire rig got me on the road in two hours and even though I carry the OEM parts now...Two years later my BMW is still shifting on Ace Hardware parts.
I like it! That's my kinda fix!
Shifter
Thanks I will keep parts in the bike to repair it. Just came back from a little run works like a charm nice and smooth the old parts that are good have a noble place in the side bag with my tool kit, now I have done it I see how easy it is to do will still look for the heavy duty kit,
Again Thanks
2011 R1200RT
When you decide that you are tired of the wimpy factory shift linkage you send an e-mail to Phil Johnson ([email protected]) and order his heavy duty replacement kit. Specify if your bike is a 99-04 or an 05 and later as the thickness of the rods has changed.
I installed his kits on every LT I owned for peace of mind!;)
1 - 9 of 9 Posts
