doing a 1st time valve adj on an 05 RT. Jim Bade's really good video says to torque the 15mm nut and then do a 180 degree rotation…….what are you rotating 180 degrees???
Did your '05 need an end play adjustment?
I thought My '05 might so on my last valve adjustment (30k miles) I took a creful look/feel and measure. Mine was clearly on specification so I left it alone.
FWIW... I never know if my valves are tight or loose before I start, I just back them all out some... then go to the specs.
It all ends up in the right place....
That's the way I was taught to adjust pushrod valves on the old 60's VW's that needed adjustment every 3K miles. Worked then, works now.
JayJay
