1 - 20 of 25 Posts
I’m looking for an action camera that will power up to my RTW while recording or last for 4 hours on internal camera battery. 4K video preferred, but 1080 ok.
Anyone using this set up, or know it doesn’t exist?
Thx
The hard part is the 4 hours internal battery! I don't know of any action camera that has that capability. My present helmetcam is the Sony FDR-X3000, which has 4k capability, but the internal battery will not last anywhere near your 4 hours requirement. I use a USB cable to connect the Sony's external port to a USB "charger" that I have plugged into the RT's front aux. outlet port, which allows me to record until my 128 GB card is filled up! :) Your other choice is to do similar thing, except connect the other end of the USB cable to a portable power bank (very inexpensive nowadays) that may reside in your jacket pocket!
Here is an example of the output from the Sony, in 4k:
Reactions: dfinazzo
Old Dawg
I like Pad also use a Sony FDR-X3000. I can't imagine wanting to record 4 straight hours of video, you would never have time get through it and edit it all. The beauty about the Sony is it comes with a remote with a LCD screen that shows the view the camera is seeing so you can aim your camera correctly and record all the highlights of a ride while easily controlling the camera functions. I get upwards of 4 hours on a battery with mine when I power it on and off with the remote and record the about an hour of video.
Here is a video from Death Valley last March on rides that lasted all day long and I used two batteries in 8 hours of riding:
Nice video Scott.
Tom, if you are looking for something to use like a " Dash Cam" running all the time, you are going to have to find an alternate power source as mentioned. Portable battery units might do the trick if you want it mounted on your person or, you could look at something like the Innovv K2 for both front and rear cameras simultaneously or the C5 single camera DVR systems. There are others like this that cost less but these are in their second gen correcting issues in the first gen and are pretty good. I have several cameras that I use, a C5 and Panasonic a 360. Using them at the same time has proven difficult as the wi-fi management apps of each conflict. What intentions do you have for the cam, that may help others suggest options. The video below was done with the Panasonic if the link works. No camera movement, only software manipulation of what the camera records.
www.youtube.com/watch?v=VznSnneBh4s
Thanks for the info and video. Quality is unreal, especially compared to my current iPhone set up. 🙂 So the Sony will charge while recording thru the USB? I couldn’t find any mfg that said that on their site. Two more questions - how long does the 128 disk last, and will it take a larger disk? Thx!
Hi
Wonderfull video
Where are the action camera placed?
Enviado desde mi Vivo 8 mediante Tapatalk
The camera is mounted to the right side of my helmet, as far forward as I was able to, on my Neotec 2.
Note that the Sony has optical stabilization, which makes the video looks very steady, and it is the reason why, in my video, my helmet seems to move independently to the camera at times!
Reactions: diegojguerrero
The 128 GB microSD card will hold about 6 hours of 4k video, and yes you can put larger microSD card in place. I don't recall the limit size though, if there is any! I am relatively new at videography, and got hooked on it when I bought my drone over a year ago. I do record my full ride, in 4k, but know that I don't have enough storage space for the normal 8 hours that I would typically ride, and so I have an extra 128 GB with me on the ride, to be swapped in at my usual pit-stop. At the time of purchase, 2x128 GB cards were cheaper than a single 256 GB card! DO make sure that you buy the very high speed microSD card though. The camera is smart enough to refuse to allow you to use low speed card to record 4K!
The remote (available as an option, or part of a kit package) not only display real-time video of what the camera "sees", but can be set up to turn the camera on or off, and you can configure it to have the camera starts the recording as soon as it turns on as well. That is how I had set up my rig.
Very handy camera, but not inexpensive! I was looking for an action camera that would do 4k video, to match the one on my drone (DJI Mavic Pro), and picked the Sony. It is a good camera, but I wish that it has many of the more "professional" type of features that are available on the Mavic.
Good information, thanks.
Discussion Starter #10 (Edited)
BTW, you are right. Sony not cheap. Do you trust the helmet mount? Did the mount come with the camera?
My intent is to get the simplest system so I can set it and ride. Much like a dash cam. Most will be edited out later. I just want to capture the highlights of the ride. Most of my rides are <200mi but don’t want to scramble to be able to record a weekend trip or two.
The stick-on mount does come with the camera, and this is the first time that I had used one. It is very secure, and after having used it for a year, I would say that it will not come off. I have it on all the time for the reason that you mention. My concentration and priority is on the ride, and I don't want to even think of the camera while riding. The distraction could be dangerous.
Another camera that you might want to look at is the SENA Prism, both the regular version as well as the simpler Tube version. I was using the regular version before the Sony. The Prism uses a mount that goes onto your helmet in the typical SENA fashion, which is to slip one "leg" inside your helmet shell and clamp on the external mount plate. Very easy do do. It also comes with adhesive mount like the GoPro and the Sony. Like the Sony (but not the GoPro) the Prism also has a 1/4-20 threaded mounting point in the bottom of the camera, and that is the standard thread for tripod mounting on any camera. The Prism will mesh with your SENA intercom and uses its control to start/stop recording, take pictures, and also uses the microphone and helmet speakers for its input and spoken output. The Prism can only take 1080p video, but the quality is quite good. The down side is that it doesn't have any forms of image stabilization at all. This video will give you some ideas of what the Prism can produce. This was taken late 2017, in New Zealand:
Reactions: scottydawg
Discussion Starter #12
PadG, I’m still looking at all options, thx for all the info. Do you have the standard BMW supplied USB plug in, in your right side small compartment? If so, is that where you plug in the camera? If not, do you have a charger device plugged into the aux, and where did you get the charger?
Scotty, do plug in and how, or are you all battery?
Thx
Old Dawg
I am all on battery. I have a couple of spares but typically just need to make one change on a day of riding.
Thx
That USB connection in the right compartment can put out only 800 mA (0.8 amps). It's in your manual. Not enough power for the Sony, but funny enough, it is fine for the Prism! I found out in my early days of using the Prism. Rode away and forgot to plug the USB charger into the aux. port on the RT, and of course, forgot to plug the Prism into external power. When I realized this and stopped, I didn't feel like going back, and so I plugged the Prism into that USB connector in the right compartment. The Prism was good for the full 8 hours ride on that connection!
The USB charger that I normally use is this one, and it plugs right into the RT's aux. port: https://www.amazon.com/Motorcycle-H...8&qid=1549115763&sr=1-4&keywords=powerlet+usb
DO shop around to get the best price! I believe $20 is very possible. I like this particular one for its low profile, but more important, it "click" in when you insert it fully into the aux. port, and seem to lock in place. I had a less expensive one before this one, that did not "click" in place, and I had lost it on the road while touring the Scottish Highlands a few years back.
Discussion Starter #15
Wow, good info guys. Thx! Pad, I remember now my dealer explained both ports and even sold me an adapter (no click, no low profile) for the aux plug. Thanks for the repeat lesson! At my age it sometimes takes a time or two for things to sink in. 🙂
Well, on to The web to find a x3000 and Amazon to order the adapter and then a ride! Already 55 outside. Thanks again.
Hey, you can't be that old, if I had started riding several years before you did! :)
By the way, if you are going to helmet mount the Sony, or place it anywhere in the bike's slipstream, you will get a lot of annoying wind noise. That Sony has a 3.5 mm audio input plug in the back, right next to the microUSB plug (for charging), where you can plug in an external microphone. This is the one that I use: https://www.ebay.com/itm/Sony-Tie-C...h=item33d54432cd:g:nrgAAOSwxbtZnLQa:rk:3:pf:0
You can tuck it inside your helmet, if you want to narrate the video, or in my case, I simply velcro it to the front of my jacket, about 1/2 way down. This will allow the video to pick up all of the ambient noises, like the engine sound, without the annoying wind howl! Watch the video that I posted earlier on a desktop computer, with fairly good speakers, and you will hear what I mean. The Prism uses the microphone inside the helmet, and so it still gets some wind noise when I have my visor up, and the sounds from outside of the helmet is a little muffled, as to be expected. I like the Sony setup much better, even with this fairly inexpensive external microphone. You can use any brands that you like.
Discussion Starter #18
Thanks for the tip! BTW, what helmet mount are you using?
The stick-on Sony mount that came with the camera, but along with that I had to get a 90deg. mount to get the right orientation of the camera and some adjustabilities. This is the 90 deg. mount: https://www.amazon.com/Sony-VCTHSM1-Helmet-Mount-Action/dp/B00R1CO5YW
It comes with a "safety" lanyard, which I don't use, because I wrap the USB cord around the mount before plugging the other end to the charger. Figured that if the adhesive let go, and the camera falls from the helmet, it would still be tethered by the USB cord.
Discussion Starter #20
Thanks again! I got it ordered. Just waiting for all the parts and pieces now.
1 - 20 of 25 Posts
