Here's my advice for anyone who wants to do a timely install with no unexpected down time:
1) The "body-bound rivets" holding on the left and right front-fairing panels were stuck on my bike. I had to destroy them to remove them. I'd recommend having some spares. Read this thread I created for more details on this.
Hey guys, I'm in the process of removing my headlight assembly to install the Cyclops LEDs. I was flying through the process and had the windshield, side fairings, and speakers out in no time. Then I got to the front fairing... I got all three screws out no problem. The only thing holding it...
www.bmwlt.com
2) Have some extra 3m dual lock for the side fairings. On my left side the adhesive wore off and the dual lock came off of the fairing. I replaced it with a piece of velcro while I order replacements from BMW. See this picture for part numbers (number 9):
3) If you're curious like I was, the torque for the M6x1.0 bolts holding the mirrors on (2 on each side) is 8Nm.
4) 100%, do not skip this step, mark the cutoffs on a wall or garage door before removing the halogens. I had to lower the aim of the new LEDs as they had a higher cutoff than the halogens. Don't be the dickhead blinding everyone contributing to the stereotypes. The procedure is in the owners manual and it's super simple. There's a lever on the bottom of the light that gives you three options. I had to go to the lowest of the 3. There's another up/down adjuster on the lights that I didn't use and isn't mentioned in the owners manual. I'm assuming this would be for a fine adjustment. You'll see it when you have the light off.
5) Definitely remove the headlight assembly. The spring clips are hard enough to operate with the headlight on a table in front of you. You'll also be doing everything blind, hoping your connections are good, stuffing wires blindly into the housing, and may drop something in the light and have to remove them anyways. Don't waste your time.
6) Clearly label all the hardware for reassembly. I was able to get every piece back where it came from. I used ziplock bags marked with sharpie.
7) Print out the PDF for the headlight removal from the service manual. See here:
After researching various threads about installing LED lamps, I'm ready to take the plunge. I have an '18 RT LC. Having replaced more than my share of hexhead RT lamps on my and riding buddy's bikes, I'd like to remove the headlight assemble and preserve the skin on my fingertips and forearms...
www.bmwlt.com
No issues with any errors or lights on the dash. Flipped back and forth many times will aiming. Went out for a 75km ride after with no issues. Huge improvement in aesthetics of the bike. Looks how it should have from the factory.
My total time was about 8 hours. I wasted a good 90 minutes on the stuck/broken rivets. Would have been 6.5 hours otherwise. It was my first time removing most of these components. If you're familiar with the bike you should be faster.
The low and high beams are way brighter than the OEM lights. The low beam does have a slightly narrower output than the stock halogens which had a very wide cutoff. The increased intensity and brightness outweigh this negative for me. The highbeam also has a slightly funny cutoff, but again the positives outweigh the negatives for me. Here's some more pictures:
