1 - 9 of 9 Posts
I have done some trawling as best i can of the archive and forum - but came up with nothing useful - so thought i'd pick the collective brains of you all.
Firstly - a handbrake .... my previous bike was a Honda ST1100 ... traded in px for my 01 LT ... the Honda had a "Middleton" hand brake http://www.st1100.org/farkles/handbrake.html - a device that could be flicked into the gap created by the application of the front brake lever which effectively locked the lever in the braked position. A quick pull of the lever released the brake (on a spring). This was great for holding the bike on the brake without having to use the right foot ... especially when stopping on an incline say at a junction or such. I'd love to be able to do the same on the LT somehow - but I have no 'engineering' skills .... and wondered if anybody has such a device or knows of where to find it?
Secondly, reverse lights - I've added fog lamps to the front of the bike - It's easy enough to add fog lamps to the rear .... but has anybody knowledge as how to add reversing lights that come on automatically with the selection of 'reverse'?? ....
Regards
Mick
Suffolk / UK
How about a reed switch and magnet mounted by the reverse lever? Feed a relay from it and the job is done.
Should you be cleverer than me, you could organise a sensor that will see which way the wheel is rotated.
Just for laughs I have hooked up a backup alarm along with some bright LEDs for reverse lamps. Both have gotten quite a bit of attention at different times. Used a very small hose clamp around reverse rod too create a cam to actuate a micro switch normally found on electric forklifts. Seems to be very water resistant. Have forded a few creeks without any problems. Wired the switch to a relay that is supplied by a fused circuit. Backup alarm is from a industrial electric cart. Again I have gotten more laughs than I can count. Does it serve a real purpose I think not. Existing tail lights are more than adequate to avoid backing into something at night and as far as the alarm goes all my riding buddies are deaf from to many years of riding without earplugs....
Here you have some pictures of a limit switch installed in the reverese lever. This switch actuates a relay that feeds my reverse alarm, gives power to the distance detectors and feeds my future reversing lights. So far I have not found proper ones that would fit in nicely, I have the wiring ready and waiting behind the rear panel though. Perhaps I will start looking at some led application...
http://picasaweb.google.com/pozoizquierdo/REVERSINGDETECTORS
Regards
Regards
Nice farkle Ari, but you have TOO much time on your hands..... ;)
Garry
Many snowmobiles come standard with a device similar to (but not nearly as ugly as) the lever in your link. It's built right into the lever, a smaller plastic 'lever' that fills the gap. One finger application, releases automatically when you pull the brake lever again. Would be handy on the LT I'm sure. You got me thinking... so I went out to the garage and found a small wedge shaped piece of rubber, pulled the brake, and jammed it in the gap. Worked great. The problem now is how to keep it handy, like on a string or something, without looking too 'ghetto'.
I dropped the LT the other day on a sloped sidewalk. Left side. If I had thought of this then I could have locked the front brake and saved the tipover wings from some scratches. As I picked the beast up it wanted to 'pivot' a little with the wheels rolling. The shift lever was buried so getting it in gear wasn't possible.
Regards
Mick
Suffolk / UK
Garry
Thanks Garry, I sure hope that would still be the case but unfortunately not...I have soooo many little farkle thingies in storage but looks like this will be the second winter in row that I barely get the oil changed and that's about all the farkleing I have time to do.
Now who ever invented the thing called "work"....:(
regards
Hi Rick
Not recalling any gap such as described, I went out and had another look at my levers. I don't have that gap .. the lever is partially housed and covered -but looking at the set up - the hole that would be suitable for handlebar mounted mirrors may be in the right place to support a device that would somehow drop forward over a compressed brake lever .... sort of securing the lever in the braked position. Assuming it were spring loaded a small further compression of the lever would release the 'clamp'.
My big issue is that I have no ability to work something up - I have no garage facilities sadly and nowhere to work any materials that I might otherwise be able to play with to try and make something work that didn't come from the kids Mechano set...... hence trying to pick the forums collective brains.
The device on the ST1100 whilst pig ugly to look at, once it was on the bike, it looked as if it ought to have been OEM - and it worked brilliantly.
Thanks folks for the feedback re the reversing lights .... from what I have seen, it looks to be a bit too complicated to make it worthwhile -may just resort to a switched white light to the rear if I ever get around to doing it.
Best regards
Mick
1 - 9 of 9 Posts
