1 - 12 of 12 Posts
some said the wire for reverse by the fuel pump had a white conn, the white goes to the brake pedal
however this wire goes to the trans, i am trying to make sure it is not something silly that is causing my reverse not to work
then I assume since I have never noticed this wire before that this is yet another aux power feed
then of course this is definitly a add on feature that took some time to get
grifscoots said:
I have one of these
How do you get one of those?
BTW, the aux power plug you hold in your hand is for another female cigarette plug.
That what i thought, do the wires look like the right ones even though it is not white?
I got my bmw MoCo mileage award (like yours) back in march, this one is from bmwmoa if your a member here ya go, ya get a cool pin a sticker a patch and a letter from them thanking you for your miles
http://www.bmwmoa.org/mileage/MileageAward.htm
Tom
Tom
I'm like Grif - got the mileage puck; no cool pin, no sticker, no patch; got the letter tho, and a plaque in a Dollar General store frame!! :rolleyes: No matter tho, ole Toad don't care cuz we don't wear that stuff anywayz. Now if it glowed in the dark, or wuz retro-reflective, we might be sendin' some stationery to MOA!! We like shiney stuff!! ;) :bmw:
Reverse speed sensor
There is a sensor on the right side of the transmission that is called the "reverser speed sensor" in the parts fiche. It's connector is near the fuel tank bottom and, yes, if it is disconnected your reverse will not work.
GB
GB
Thank you, it is connected, any idea how to diagnose this part? is this something the trannymust come out to replace or do you only have to remove the trans if the reverse gears are bad inside the tranny
Thanks again
Tom Gallo
Discussion Starter #8 (Edited)
yup, if I am finding the correct plugs, one goes to the right side of the trans case just behind the brake pedal area into what looks like a gear indication/neutral switch then again, I'm not sure can't seem to find a good pic in the service manual, here it is
when i flip the lever the rear wheel will not budge like it should be. when I push the start button, there is a box on the left side of bike behind the side panel that will click,
it clicks every time you push the starter button it must be the reverse control module from there I can't seem to find anything out, i see no damages wires even laying under the bike hoping to see something
I would think if the little reverse gears inside the tranny were damaged you would be able to manually spin the rear tire
one thing I wish is theat there was a decent diagnoses book out for these beasts. I need a procedure to try and repair this
thanks for your help and time
Tom
grifscoots said:
Has to be the control module, that's where I'd start.
that makes sense, wonder if there is a way to check which pins for power to be sure, anyone I could ask that ya know of?
Tom
Discussion Starter #12
grifscoots said:
Hey Tom, just another thought: take a dead blow hammer, rubber mallet or the like and give the unit a good thump.
dang knowin myy luck it would be somethingother than that unit and I would kill it <g>
it;s all back together now, headin out in the am for a decent ride, the wife is with , so I have reverse, she'll just have to get off her bike <g>
I'll try it next week though
See ya!
1 - 12 of 12 Posts
