I've had my 2000 1200LT for almost a week now. And, I've been daring enough to try the reverse. About 20% of the time, I reach down and flip it into reverse, press the starter button and the bike backs away.
The other 80% of the time, the switch won't move to the Reverse position.
Can anyone shed light into what I'm doing wrong?
My process:
Bike is running.
Bike is in Neutral.
Flip the Reverse selector (sometimes works)
Press starter button
Bike goes backwards
Flip the selector to Forward
Drive away.
Thanks.
Dave
Motor running, in neutral then rock bike back and forth as moveing switch to reverse. Works for me!
There is a hard lockout that prevents it from moving unless you are in neutral. Then you have a straight cut gear that must slide onto the transmission output shaft. That is where rolling forward or backwards a little bit helps as Ron pointed out.
not to overstate the obvious, but you can't have the kick stand down when you do it either
Thanks, folks.
I was rocking and rolling before, but evidently not enough.
Since the end of Cincinnati Reds' season (around 5:30 pm today) , I'm now 3 for 3 on getting it into reverse.
Dave
You can also tap the start button if moving back and forth is not an option. This is how I engage it every morning backing out of the chock I park in.
Regards,
There is always K-Y jelly. makes the boat very slide able and able to get in better
Just like my old man told me, sometimes you just gotta jiggle the handle to get it to go down :)
