OK... My Lt is all over the garage, I have replaced the air cleaner and have the fuel pump and filter out. I intend to put new plugs in and have a valve cover gasket if I get enough guts to check the valves. I have a front brake line that went bad and will be replacing that as well.
I was looking at the radiators and the fins are plugged with bugs.
Any tips on how to clean out the fins without disassembly?
Also I have never checked valves myself... any pep talks out there?
