I've owned my LTC since new (2002)... battery went dead over the winter even though it was on a battery tender. Just replaced it with a new Odyssey. Everything seems fine, EXCEPT pressing the button on either remote doesn't disable the immobilizer (the light is on solid) even after replacing the batteries. Also, the front and rear turn signals/hazard lights are on solid (never seen it do that before). Cycled forward and reverse. It's in neutral. Side stand up/down doesn't change the behavior. ABS seems to cycle normally. Horn works. Suggestions?
