1 - 13 of 13 Posts
This is my 1st K bike after several Airheads and an Oilhead. It is a 2009 LT. IT ARRIVED ON Wed and the low beam headlight doesn't work. It is the factory xenon option. I did several searches and several people have had the same problem but no one says how they removed the bulb. Several removed the entire nose but I hope to avoid i that. I have removed the wire bail that holds the bottom and the ballest but the cover seems to be still stuck at the top. The Clymers only shows the half in bulb replacement. Any advice?
Give this a look. I hope it helps.
Thanks. Unfortunately it dosnt help. The factory HID is a completely different animal and removing the cover seems to be the difficult part. The manuals don't show anything on the Xenon headlight.
There are some posts about the ground wire to the headlight going bad on here. Send a message to a member called jzeiler. I think he knows everything. If anyone has run across a factory HID, it would be him.
Good luck!
Unfortunately I have not had the pleasure to mess with one yet. I do have a factory HID on my K1300GT but it has not failed yet. From the looks of the prices it is very expensive. Bulb is 280, ballast is 150 and the control unit is 597. Might be cheaper to gut it and install an aftermarket HID.
I posted this (https://www.bmwlt.com/forums/k1200lt/125498-oem-xenon-low-beam-dead.html#post1581569 ) a number of years ago when I was having problems with the Xenon low beam on my 2007 LT, shortly after buying it. It might be of help and it has a link to another post that describes the operation of the xenon light. I don't think the light has a "globe" in the traditional sense that you would typically expect. My headlight would come on when the bike started and then go out. Giving it a thump on the nose cone got it working again but then it started to go out when you most needed it. You know, mid-night on the freeway doing 100km+; great fun. I eventually found that the plug connection to the light was loose. All I needed to do was give the contacts in the plug a bit of a squeeze and that fixed it. Over six years ago now and hasn't played up since. This may not be your problem but check your wiring and connections first before committing to big chunks of cash.
I have a new ballast if you are interested to send me a PM.
Relkin, I have read your post and the other one that you reference. Has far has I can tell, there is no information on removing the back cover to the low beam without removing the entire nose. I know that you removed the entire thing, but is it possible to do without? Also, do you recall how the clips work for the wires on the ballest? I have removed the 3 screws that hold the ballest to the cavern and the wire bail at the bottom.
Mr1150gs, I will certainly keep that in mind. Is it from BMW or did you find a substitute?
It is the BMW part for the xenon. I had the same issue but it turned out to be the controller.
I couldn't find any information at all that described pulling the xenon low beam headlight apart and I didn't remove the nose cone or headlight assembly from the bike. It's a long time ago now but I think I had most of the fairing apart to do some other work. I haven't looked at it since. I can't remember how the clips work but I don't remember having to much trouble disconnecting them. Just tried to have a look but I can't even see them now; my nose cone is a bit crowded with ballasts and paraphernalia for two other sets of lights. The bikes a bit jammed in at the moment. I'll try and pull it out and have bit of a better look.
Discussion Starter #12
I found an old post on the MOA forum that suggested removing the windshield and the top of the dash and the bulb is accessible from there. I will try that.
I have tried thumping the headlheadlight lens and pushing the starter button after it is running to no avail. Any other suggestions appreciated.
It would be nice for others with the HID headlight if you would update what you found out and how you fixed the problem.
1 - 13 of 13 Posts
