Hello,
Does anyone has experience or recommendation on replacing the H1 and H7 halogen bulbs with LED bulbs?
Also, is there a easy way of doing it?
can you please tell which brand, or place where you purchased it.
Maybe a link
Loads of us have done this very successfully and are very happy with the results (This is on the 1200 Wethead which in terms of the lighting setup is identical).
Just take a search of this forum (as well as the Wethead section of the SportTouring forum).
I purchased the Cyclops LED kit for my 1250 RT which includes all of the bulbs high/low. If you want to save yourself a lot of aggravation the best method of installing them is to remove the entire light housing and install the kit. Took about 4 hours or so to completely remove, install, and replace the housing. The difference is night and day. For me, definitely worth the effort. Now the headlights match the LED rings and don't appear an awkward yellow as before.
Reactions: Rainman48
My review of installing the Cyclops hi and low beam LED kit.
