1 - 2 of 2 Posts
Kevincook:
Kevin: I purchased the lower clutch pressure hose from "SilverBuffalo" and should have it later this week. Have you set up a time to replace your hose yet? If not, how about another Tech session to replace these?
A Tech session would be best for me seeing as you have already cut out the socket for the swing arm. Also received some short-cut info from Eric (Sofitel505) about how to pull in the replacement without removing the gas tank.
I will bring my digital camara to document the entire procedure if you want.
Let me know your thoughts.
Hi Chuck,
I'll look at the calendar tomorrow. I'm not sure when I would be able to do it. I know the next two weekends are booked already. I had my bike all apart most of the weekend doing maintenance and installing lights, relays, fuse block, etc.
Kevin
1 - 2 of 2 Posts
