Well, I gotts a drip from the Hall Effect cover, so I need to replace the timing cover sealing ring. Got it on right the first go round, but not the second, and it is pretty mangled.
I'm not finding too much info on how this is done.
For starters, I can't figure out how to get the oil pressure wire to go through that small hole in the water pump, and wonder how I'm going to get it back in. The water temp wire came out easily.
I've been looking for a picture of the special tools with no luck:"Press the sealing ring in from the inside using pressing-in tool, BMW No. 11 1 610, and handle, BMW No. 00 5 500.
Will I be able to install the seal with the cover still attached to the engine by the oil pressure wire?
I've found a pulley that is about the same diameter as the seal and wondered if I could use a C clamp to press the seal in place?
