My left rear speaker is not working. I did have a problem with the radio once before and I did the disconnect the battery trick, it worked. Now my left speaker cut out. I took it off and tried it on the right side and it worked. I checked to make sure the connections were tight. Do you think it is a channel out on the radio or just a loose connection at the stingray? What do I have to remove to get to the actual radio connections? I have never taken the tupperware off. Is my first time coming?
I just had my radio replaced under warranty for this. I could hear a small pop sound out of the speaker when I turned the radio on/off. This was confirmation that the wiring was good.
I don't hear anything out of it. I need to see if this is covered by my extended warranty.
My right rear channel is bad. I checked all the connections and concluded it was something in that channels output amplifier. It would cost to much to get fixed and most of the time I listen through the helmet speakers anyway, so I just live with it.
Yep, strip her off!
jnybgd said:
My left rear speaker is not working. I have never taken the tupperware off. Is my first time coming?
Oh yes. Even if just for the experience. It's not so frightening the next time.
Took the clothes off mine again today. You know I have had her clothes off so many times, I'm surprised I haven't had to marry her :rotf:
Decided to fit the Minidisc changer and interface today, but sadly ran out of time so had to bring a van home instead. :mad:
YOUR PROBLEM...​
Take the stingray partway off and check out the three connectors on the upper left. I found the middle one needed careful squeezing up, taking three tries before it was reliable. You need to get a finger or two behind it to bear against.
I also just had my radio replaced for the same thing.
Yeah, I know I need to just set aside the time to do it. That way if I have to, it won't be so bad. But I ride everyday and my wife crams my weekends full. I'm sure no one else has this problem :)
